The brake lights are staying on intermittently. Everytime it's the hand lever. I push it back and the lights go out. I have replaced the switch and the levers.
Any other suggestions? Bugs me and the people behind me.
Discussion Starter · #2 ·
bump
I had the same issue as well as trouble setting the cruise. Turned out to be bad master cylinder (check ball) on the right handlebar. The dealer rebuilt the M/C and all is well.
I have a spare I'll switch it out and see what happens. I will look at a exploded view first and see what its all about. Thanks Chris
When was the last time you lubed the levers. It may have worn from lack of lubrication, and that may be why it isn't going back all the way. It doesn't take much movement to kick that switch.
some people have had that problem with aftermarket levers...might want to make sure you have OEM levers on there...ride safe...
Scott
