1 - 4 of 4 Posts
On non-abs bikes are the front and rear brakes still linked?
If I pull the front brake lever does it also operate the rear at the same time?
Gordon :?
Yes ! So what extent ? I'm not sure without going to the book.
Gordon :?
Yes! They are linked exactly the same as the ABS system. The ABS system just adds a modulator between the master cylinders and the calipers. One for the front and one for the rear.
When you pull the front brake lever you operate 2/3 of the right front and 1/3 of the left front. This causes the left front caliper to move upwards and apply pressure to a secondary master cylinder that operates 2/3 of the the rear brake.
When you use the rear brake pedal you operate 1/3 of the rear brake and through a delay valve 1/3 of the right front and 2/3 of the left front which operates the secondary master cylinder that operates the remaining 2/3 of the rear brake.
1 - 4 of 4 Posts
