1 - 8 of 8 Posts
Hey everyone. Getting new tires, so, I'll have my wheels pulled off soon, and will be inspecting the brakes, ect. I'm at almost 9000 miles.
when I measure my pad thickness, what is considered the minimum?? I'm trying to figure out how much pad life I have left, since I'll have the wheels off anyway.
Any thoughts would be appreciated!!
The pads have wear "cuts" and when you can't see or are really close to not seeing them, then they need changing. I got 37K out of my first set. I have a little over 60K now and the pads are still looking good.
If they still have at least this much left: iii . . . you're good to go for another few K miles! Anything less - I'd replace 'em.
Awesome info! Any thoughts, Honda vs. Aftermarket??
From what I have seen you should get at least 25,000 out of a set of pads and I always run Honda pads.
Kurt :thumbup:
Oem
Just had first set of front pads replaced at 32,000 miles when I replaced the front tire.I went back with the Honda OEM pads as they have worn well. When I replace the rear tire next time I'll replace the rear set of pads.
I'll stay will what has worked well for me and most all I have talked with.
OK, well, since my bike is just shy of 9000, guess I wont buy any brakes. I'll inspect and measure them when I pull the rims off just to be sure - but, I'm glad that I don't have that extra expense right now!!
Thanks y'all!!
1 - 8 of 8 Posts
