From what I have seen that is not unusual. I just wipe it out when I change the air filter.
Another reason to not change your rear wheel with the bike laying down perhaps??Is it possible that my crankcase breathers are O.K. and this is just a result of having dumped the bike over a couple of times, or do I need to pull them and test/clean/replace them?
That sounds like a good plan. I think I'll try that.Lee
That is pretty normal, what will add to it is overfilling the crankcase with oil and not emptying the drain tube.
Just clean it up, drain the crud from the drain tube under the left cover by the spark plugs and be carefull when filling with oil. Many time some oil will remain in the case after draining and then you add 4 qts and now there is too much. I always add 3.75 qts and then start the engine and let it run for a minute, shut it off. After a few minutes check the oil level by the dipstick and add as required.
