I have a Bushtec Trailer hitch installed on my 2015 Level 1 Goldwing. I tow a Hannigan GL Series trailer.
The hitch is a vertical receiver type and mates with the frame mounted portion of the hitch by sliding inside a sleeve and is locked in place with a locking pin. There is also a bolt on the receiver (at the back of the hitch) that is suppose to be tightened. I can no longer tighten this bolt, therefore the hitch itself is can move a little inside the vertical assembly.
My question is the fact that I can no longer tight this bolt an issue? I have tried some sprays on the bolt to try and make it rotate at least outwardly so I could determine what the issue might be. So far, I am unable to rotate the bolt and did not want to apply so much force for fear of stripping the threads.
I have tired to contact Bushtec several times to ask this question and have never had my calls returned (Tech Support).
Thanks.
Thanks.
