I carry 2 new bearings in the trailer all of the time. IF I ever have a bearing issue, I've got a brass punch and a hammer to remove the old ones. I then use a old bearing to tap on with the hammer to seat the new ones. The wheels take 2, one on the front side and one on the rear with a metal bushing between them.I also carry a spare replacement bearing including proper tools to replace it, in the trailer.
I keep the bearing in a zip lock baggie to avoid any dirt or debris from getting into it.
I need to greese the bearing in the wheels but it doesn't seem like they come out, has anyone done this and can give me some information on doing this?
Yup like Roadie said....very simple and easy to do when/if needed....very quick to do.You only need to pull the wheel off and while holding the wheel place your fingers in the center of the bearing and spin the wheel....the bearings should be smooth turning...if any roughness is felt, it's better to replace the bearings. Then you put a light coat of grease on the axle to protect the axle against corrosion. Slide the wheel back on and put some blue locktight on the threads of the axle and tighten the axle nut.
