1 - 12 of 12 Posts
Any of you out there who have installed the Bushtec V2 hitch. I have a used V2 I bought from another member of this forum. As was expected, some of the hardware is missing. Not really a problem as it all seems to be standard off the self type stuff only grade 8.
There are 2 missing parts that are a problem. The parts list calls for 2, 3/8 spacers. It doesn't state the length or even show a picture. Would any of you out there in Wing land have any information about these spacers?
Joe in Modesto
Joe in Modesto
complete install "how to" here:
http://mysite.ncnetwork.net/res8tr14/bushtecv2trailerhitch/index.html
spacers are shown here:
http://mysite.ncnetwork.net/res8tr14/bushtecv2trailerhitch/id13.html
.. the spacers (black in the picture) just hold the Bushtec "struts" away from the frame
(so they pull straight down instead of off to the side)..
Dennis
Thanks Dennis, I looked at that site, but did not know that those were the spacers refered to in the instructions. Looking at the picture, it would seem that they are about 1/2 to 3/4 inches long. I guess that I can just install everything else and see what length is needed.
Joe in Modesto
Ok, from the picture and a visual observation of my wing, I see no reason why I can't just use a stack of washers until the spacing looks right. I'll take a trip to Lowe's in the morning. I wanted to replace all the Nylock nuts anyway (they're not supposed to be used more than once).
Joe in Modesto
Joe in Modesto
Thats what I was going to suggest, I can't undestaand what happened to them.
Sorry for any inconvieniance.
John
Hey John,
I don't feel inconvenienced. When you buy something used and sight unseen, you must expect a few stumbles. If I had wanted a perfect installation, I would have purchased a new hitch and have it installed. I still feel I got a good deal on my hitch.
Joe in Modesto
Hey John,
Joe in Modesto
Ok Joe, does it look like everything else is going on OK?
Morning John,
So far things are going ok. I just got up and after breakfast will see what time Lowe's opens to get the rest of hardware. I need to finish up on the mechanical side so I can ride to work tomorrow.' I still need to order the wiring harness (from Electrical Connection) and make up an adapter to connect to my wife's trailer. It has a 9 pin round plug. It is kind of unusual. I found a receptacle online from a company called wirecare.com. I think it was called a "Deutsch" (sp) type connector. Others of you wingers might want to take a look at this site. It has lots of stuff that could be of use to us when working on the electrical side of things. I hope to be finished by noon. We have a "4th" get together to attend later.
Joe in Modesto
Discussion Starter · #11 ·
Its done!
Well, at least the mechanical part. For the most part it went pretty well. The web site posted above was a lot of help. Surprisingly, I had absolutely no problem getting the seat bolts back in. I was really worried about that part.
Thanks to all who provided help, information, or encouragement.
Joe in Modesto
1 - 12 of 12 Posts
