1 - 4 of 4 Posts
I bought a Kury antenna mount flag and the mount has to slide over my bikes antenna to mount to the lower antenna base. I can't figure out how to remove the CB dummy load so I can get the flag mount on ? Has anybody removed this antenna ? The dummy has 2 allen set screws in it, but when I take them out I still can't get anything to budge. I applied enough torque that I know I was close to breaking something. Any ideas ? :banghead:
I took mine off by taking the bottom set screw out and grabbing the lower piece of aluminum carefully with a pair of channel locks. It unscrews from the lower part of the antenna mast. Worked for my '02 anyways. Hope that helps...
Unscrew antenna mast from base, put antenna in vise, just below the loading coil, use an 8mm wrench to unscrew. Make sure to wrap the mast with leather or similar material to protect from the vise. Not necessary to loosen any of the set screws as they have noting to do with removing load.
1 - 4 of 4 Posts
