Well got the ECM, O2 sensor and CB fixed?
Everything ok except for the CB. Here's the problem--I can modulate about 4-8 times with my radio on at the same time. Then all of a sudden the MUTE stays on the radio and the CB works fine. This was what they were suppose to fix--Any ideas what I need to tell the dealer? Yes-it will work the correct way if I turn the bike off and restart.
Thanks,
phil
Phil,
Are you sure that the squelch is not set too near the threshold?
If the CB volume is turned down, and it were to recieve or if the squelch would open from noise, it would mute the stereo and you wouldn't hear anything from CB?
Bill
Yes--I have tried that --so--I did call the dealer and he said to bring it back up--they will retest and see--well I would like to point him in the right direction--if I can.
phil
Chard Member
Many of the first 01's were doing something like that and it was because of bad audio units!
What Red said. Honda replaced my first TWO CB's for that very reason. All within one month. Third one has run with no problem for over two years.
