I have checked a few 1800 valves and so far not needed to change any shims. Where is the best place to get the tools necessary to loosen the chains if and when i need to do one? Just asking
Wayne
Wayne
Wayne, This is what Digger used and it also worked with my ABS wing This tool is not the one listed for the Goldwing but it works better, It is used on other Honda Cycles.I have checked a few 1800 valves and so far not needed to change any shims. Where is the best place to get the tools necessary to loosen the chains if and when i need to do one? Just asking
Wayne
This is where I bought it last year at a discountI looked the tensioner tool up on DLP and it said number not found. Is there an alternate #, or maybe tools are in another listing?
I was able to order the left and right detension tools (as identified in the service manual) from my local Honda dealer.I have checked a few 1800 valves and so far not needed to change any shims. Where is the best place to get the tools necessary to loosen the chains if and when i need to do one? Just asking
Wayne
Cal-D: I do have a machinist background however i do not have access to a lathe. Thanks any way.Wayne
If you have access to a lathe, drop me a PM with your email address and I'll send you the drawing to make your own. A board member posted this drawing a few years back, I made two and they work great.
I watched Freds video, made my own tool like above. I also found out that if you pull the strring all the way out until there is resistance and then go slightly past that resistance, the tensioner will lock in that position and you can check the valves,In a world full of rip offs this tool (07AMG-001A100) is one of the most laughable ones. Must cost Honda every bit of fifty cent to make, most places online want between $90 and $100 for them and you really need two. All you really need for the left side is a pocket screwdriver and a hemostat. For the right side I cut the blade off a pocket screwdriver, slipped a coller from a model landing gear on it, replace the set screw with a 3 mm bolt about 12mm long and tied a lenth of string to the bolt. I wind the string three or four times around the shaft portion, insert into the tensioner hole, pull the string until the tensioner retracts and tie the string off somewhere on the engine. Totol cost for everthing, close to nothing as I get the screwdrivers as freebies at work and I have gobs of model stuff lying around (lifetime modeler). Thing I paid a dollar for the hemostat at a flea market my wife dragged me to one time. Watch Freds vidios and you will get the idea for the left side, use your emagination for the right side and you can save $200.
I have an ABS model and I guess I was to ignorant to know it was harder on the right side.Digger does it again! You are the best archive "digger-upper" I have ever seen. Glad to see you posting! We miss old friends around here. Keep on digging up these old gold nuggets!
:joke:
PS: I also use the non wind-up tool from Honda that is for some other bike at the RIGHT bank and use a small flat blade screwdriver and clamp at the LEFT bank. After several service inteval adjustments and reading what others have reported here I am comfortable with checking the lash without loosening the timing chains; I simply make a mental note to have the front cylinders', #1 and #2, setting slightly toward the higher side of center spec. The tension barely even affects those two cylinders and I have yet to witness andy difference in the other four cylinders. Making changes in shims? Ya gotta loosnen them one way or the other. ABS bikes are more tedious on the RIGHT bank for sure. A bigger difference than that made by the chain tension is the error one can get if one neglects to clean the oil off of the bottom of any removed shim and its seat in the bucket.
