1 - 16 of 16 Posts
I have done this a few times but my question is...should I ride it to warm up the oil or just drain it cold? Sorry for the stupid question but want to make sure I get it all out..
I usually take mine for a 20 mi or so ride to get it warmed up a bit so that it drains faster and any junk that might be in there gets stirred up and comes out too. Once I pull the drain plug I leave it out about 15 min or so to make sure everything is out. Make sure you use a 6 point socket not to damage or round off the bolts.
Don't think it matters. I just change it when its ready (whether I've just ridden the bike or it has been sitting for a day). Honda certainly doesn't care one way or the other so I don't worry about it.
Yea, the Service Manual doesn't state one way or the other.
Do not overtighten the drain plug :eek:4:
When I got this bike the first thing I did was change motor oil and final drive.
I had to end up chiseling the damn thing off. Some ape must of really reefed on it. Fortunetly a friend of mine triked his and had the final drive so borrowed his plug 'till a new one came in...
What kind of OIL
I have had my 06 for a little more than a week, and changed it , with the purple something from the auto store , it said it was ok for motorcycles and it had the hy? in it , cant remeber all of it its been a few days that Ive changed it!!!! :shrug: Do I need to get Honda oil or am I ok ?????
rear end oil change
'06 Navi:
I've changed mine 6 times (every 25K) and haven't warmed it up yet. What I do, though, is after most of it has drained, I squeeze some new oil in and let that drain out, in case there's still some old stuff or something else that shouldn't be there. No problems yet.:bow:
Must have GL-5 rating. If not get it out!!:22yikes:
I change it cold.less chance of burning hands on a hot ehaust that you'll be working VERY close too.
And less risk of different metals fighting each other in the release of the drain/fill plugs as well.
You can do it any way you like,But I have never had a problem doing it cold.
Just wait until it stops draining and then refill.
Discussion Starter · #12 ·
Thanks for the input. Did take it for a 11 mile ride. Warmed the oil up some
and drained out good. The last time I changed I did not tighten the fill/drain plugs very tight. They didn't leak a bit either and they came off real easy!
:thumbup:
Hot or cold probably does not matter but i change mine usually after a ride it just seems warm oil flows out better :roll:
Cheers :thumbup:
I usually change cold, though I do not think it matters. I take off top bolt then bottom and drain in a disposable cup. And use a small pump oil with a flexible spout can and leave botom bolt unscrewed and wait until I pump out clean Honda gear oil. Then put on bottom bolt and pump in some oil. Manual says 4 oz. I pump 6 oz usually.
I have always changed mine while its cold...I change it EVERY oil change...next change, I'm switching it to synthetic....ride safe....
Scott
warm oil
warm it up first,when its warm it runs thiner,so your draining every drop faster.
1 - 16 of 16 Posts
