I am in the process of going wireless (Sena SMH10/SM10). I have the cable that connects the on-bike headset cord (Sena SC-A0121). However, the on-bike headset cord travels back to a red connector. Does someone make a cable that would fit the red connector on one end and was 3.5mm male plug on the other? That would make the install much more tidy when tucking everything into the left dash pocket.
Not sure about a cable, but one of these might help:
http://www.spoiledbiker.com/harleyadap.html
Kennedy Technologies (http://www.cellset.com/) makes a lot of plug-n-play adapters for the GL1800 -- they might be able to set you up with something.
BTW -- how does this setup work? Are you still abel to listen to the audio system in stereo?
How about the CB? Do you have one and are still abel to use it through this system?
Thanks ...
You might try Rocket Moto in Hollis NH. When he does an install of the SM10 on a goldwing he makes a cable that does exactly what you want. He might sell you one.
Thanks ...
The SM10 is a transmitter only. It does allow both rider and co-rider to listen to the onboard system in stereo over bluetooth but wont go the other way. Sena makes another unit that will allow full function of the cb but will only connect to one headset.
