CAWing,
I do a lot of tire testing and for reason I will not go into here right now, I did put a set of the motions on my little girl and went strait to the mountains and played in the twisties for a short time with no braking in or scuffing done to them at all, of any kind...
I only put 158 miles on these tires at that time...
When installed I did check the balance and unlike the Cobras they did require some weight, F ½ oz and R 1 ½ oz, after checking them I performed the install with no weights... I use Centramatics to balance my tires...
I did push them as heard as I’ve ever push my Cobras and found them to be very stable in tight twisties with plenty of elevation changes...
I could not bring them to push or brake loose just like my Cobras...
As I was running a test on these tires and getting ready to take a trip when I got back home I took them back off for another time and put my Cobras back on...
I now only have a little over 500+ miles on these tires and still they are very good tires, they so far perform very well in wet weather also...
Sorry I can’t help you as to how long they will last...
I hope this helps some??
Good luck with your new Conies, Personally love them so far... :thumbup: :thumbup:
