:lol:Don't forget to slip your owner's manual back into the left side bag right after you read the part about adding and checking coolant.
:lol:
EXCELLENT!
My answer too!!! And, don't forget ... read your owners manual ... not mine, not his, not that one, but yours ... from year to year they can be different.:lol:
EXCELLENT!
Hmmm....that's odd. The owner's manual for my 2010 says to check to coolant level in the overflow tank when the engne is at normal operating temperature.Check it while the bike is cold.
:agree:This is one of those topics that can easily get lost in translation. You always check the coolant level in the RESIVOIR TANK while the engine is at op temp. However, if you want to see the level in the COOLING SYSTEM itself you have to wait for it to cool or you will be sorry for obvious reasons.
Not much on a manual. Just common sense.Hmmm....that's odd. The owner's manual for my 2010 says to check to coolant level in the overflow tank when the engne is at normal operating temperature.
Different procedures for different model years, perhaps?
That was answered above ... "read your owners manual ... not mine, not his, not that one, but yours ... from year to year they can be different."Hmmm....that's odd. The owner's manual for my 2010 says to check to coolant level in the overflow tank when the engne is at normal operating temperature.
:agree:Not much on a manual. Just common sense.
If you want to check the level in the radiators , it would be wise to wait for the bike to cool down. So you might as well check the level in the overflow tank at the same time. Just make sure it is full. Sure the coolant will expand a bit maybe, but that is why there is an overflow tube on the tank. If it gets too full it just drains to the ground.
Really not too important what the level is in the overflow tank . You can ride coast to coast with not tank at all. All it is for is expansion and or recovery if you were to have a small leak or water evaporates from the system and you need a little make up.
Never one to worry about things that do not merit worry.
I would be surprised if the procedure has changed from th e'01's to present. Engine at full operational temp, engine at idle, on center stand; IF my memory is right (which is questionable). You can check the level without removing the side panel or messing with the dip stick if you look underneath the bike and go by the lines on the front of the tank (belly pans obscure the view).That was answered above ... "read your owners manual ... not mine, not his, not that one, but yours ... from year to year they can be different."
