Need your help on this one. I had the Silver Taz in the shop for the common coolant leaks, clamps not tight. Now when I check the coolant level after everything has cooled, it is down to the bottom of the 3/4" hose that feeds the right radiator. After topping it off many times the overflow tank is full and I mean full. So I vaccumed the coolant out of the overflow tank. Talked to the dealer and replaced the cap. After several more rides, cool downs and topping off the radiator same thing is happening. In the past when I checked the coolant level it was full to the filler neck. Any ideas on this one. Bike still runs at same temp on the gauge never been hot 02 with 51000 miles.
