1 - 4 of 4 Posts
I screwed up and pulled the wrong end off. While trying to pull the hose off the container I pulled it loose from the other end. I cannot find where this was attached. I think I need to pull the tank but before I do that....
Anyone know where to look and the easy way to put it back on?
Discussion Starter · #2 ·
After looking at the component location map this tube appears to be just an overflow tube. And looking under the bike I find another drain tube in a bracket that has enough room for this hose too.
Can anyone confirm.
There are two hose connections on the coolant reserve tank.
The overflow connects to the front side of the tank, the side the fill or dipstick is on and runs down as an overflow.
The other one is the overflow/suction regulated by the radiator cap and is connected on the back side of the tank on the top and has a 90 degree fitting on it.
Most likely have to pull the tank to get to it.
1 - 4 of 4 Posts
