I recently returned from a long trip (Illinois to Maine) and my 2005 Goldwing performed flawlessly. I am in the habit of using the clutch to kick of the cruise control. In the past just a very light touch was necessary to accomplish this. Today, however, I attempted to cancel the cruise using the clutch and it would not release the cruise setting. Both the foot and hand brake will release it. I am assuming that there is a switch built in to the clutch lever that is maybe dirty or has gone bad. Any tips that would save me some time and trouble would be appreciated.
Cruise Control and Clutch Lever
Brett: Pull out on the Clutch lever as if you were going to adjust the length of throw and look in between the lever and the handlebar. You will see a little microswitch. Spray it with Electrical Contact Spray and work the clutch lever in several times. Do this a few times with the Contact Spray and it should start working. If not it may be the little microswitch has gone bad.
It is a commone problem. The handle bar switches (3) go out from their exposier to climate. They often will not clean up with a cleaner. I no longer evern try so I just replace them. They range from about $8-18. Below is a link to the one you need. It is part number 7.
http://www.hdlparts.com/fiche_section_detail.asp
Don't use any sort of lube (WD-40, PB Blaster, Liquid Wrench). Go to your local Radio Shack and get Contact Cleaner. Like Greg said, often that doesn't work. Replacing the switch is a 10 minute job if you've never done it before. One screw and two connectors.
Here is the switch. It is a dedicated switch, only used to cancel the cruise. It's the first one that "clicks" when you touch the lever. As Bartman said, it is very easy to replace :thumbup:
Everything that was said above is true. It has happened to my clutch switch twice. I think I'll buy a new switch next time, I hear they are cheap.
Discussion Starter #7
Wow, I love this site. Thank you all for the info. I will try cleaning and order a new switch to have just in case.
