2012 GL1800, 85,000 miles...
At times I cannot engage my cruise control, or it may take many attempts to get it to engage and when it does engage it drops off, sometimes immediately and some times after a few miles or many miles. I have noticed, for a long while now, my right hand brake lever is very sensitive to shutting off the cruise control. A feather tap can shut the cruise control off. I like the sensitivity but don't understand how it can be so sensitive. I think this is the reason my cruise shuts off. It seems that if I lightly play with the lever when riding I can get the cruise control to engage. Is there a brake lever adjustment for the cruise control? I have not been able to find a brake down (no pun intended) of the brake lever assembly. Could it be the brake lever bearings?
Can someone explain how the brake lever interacts with the cruise control and how I might fix it?
Another cruise control question: I watched the Cruiseman's videos on the cruise control adjustments barrel, located above the air filter. When the barrel is being adjusted, what adjustment is being made? How would I know if an adjustment is necessary? Could this be the adjustment I need to make? When my cruise control is engaged it works fine.
Help greatly appreciated!
