1 - 14 of 14 Posts
Looking at buying this heated jacket liner.....It is their house brand "Sedici"......$169.95 with a free heat controller (a 59 dollar value)....
Anyone have any experience with Cycle Gear's house brand heated clothing??
I also endorse this product made by Sedici but lifetime warranty from Cycle Gear. On my initial purchase I had bought a size too large and only realized this after a New Years day ride. I called my local Cycle Gear store (Knoxville,TN) and explained what I had done and even though I had worn it for a couple hours they gladly exchanged for a smaller size.
I have had mine 3 years, i use them with wireless controllers, no problems what so ever. They will run them on sale in the spring for $119.
Does anyone know who the actual manufacturer is? I've been patching my old Gerbing's for a while now need to start thinking about some new heat.
I don't remember which brand it was, (gerbings or tourmaster I am thinking) but we were comparing our jackets which we had both just purchased, they were the same jacket, just the wiring connections were different.
I've used one of their heat controlers for 3 years. Finally lost its OFF click, but still works fine. Using a Gerbing jacket. Very nice too.
Discussion Starter · #9 ·
I have done a search and the only thing that came up was Sedici by Hotwire.....I'm going to do a chat on Cycle Gear's website and see if they can answer....They came up with a quick answer when I asked about the wattage rating, it's 83 watts with a max draw of 7.8 amps.
I'm going to buy the heated jacket liner, mainly because Cycle Gear seems to be a good vendor to do business with, plus a lifetime warranty on the item....
Cycle Gear Heated
And they have stores just about everywhere with Customer Service A1
I have the Jacket-Pants-Glove liners without issue but I only used them one winter but they were flawless! I kick myself for not trying heated gear sooner!
I had the full first gear setup (less gloves) and hated mine. Talked to a guy at cycle gear where i bought them and even after 2 years they were willing to give me my money back. If I could have found the receipt I would have something else. They even looked through their computer but a system change lost records at a certain point. They actually work well enough now but only since I upgraded to a bike with a faring and a good alternator like the gold wing. They weren't capable of functioning on a bike with a faring the size of a postage stamp and with a little alternator like the Kawasaki ZRX.
It actually worked pretty well but only after you top about 80 miles per hour. I just didn't want to have to try to explain to the LEO that had to pull me over for speeding that it was so cold that I had to go 95 in a 45.....
I like cycle gear and am tossing around the idea of upgrading to their Sedici gear if I only had extra monies...
I used my new Sedici heated jacket liner and gloves yesterday. It was 40 degrees when I left and I quickly had to turn the gloves and the liner down to it's lowest heat setting. This stuff works great. I went to the Cycle Gear store to buy the gloves because they were on sale for $119 and change and wound up buying the liner too. It was $135 and change with the controller. With the lifetime warranty and the price, plus the stuff works, I don't see how you can go wrong. Thinking about going back and get the foot warmers also. If you can connect them without using the pants, I probably will.
New Low Price
I purchased 2 jacket liners last week in the Tamarac, FL store. They are very light & thin. They work great on the lowest of 4 settings.
Select high and you will be well done :22yikes:.
Yes it is cold in central Florida on the slab at 45 degrees Fahrenheit while riding at 80 MPH :nojoke:.
Latest advertised sale price for the jacket liner, controller and fused direct connect to battery is at $127.49.
I did install a 40 AMP relay in line to handle both jackets on the direct battery connect. I used a quenching diode on the relay coil since I use low beams to trip the coil (takes 16 AMPS off battery when cranking engine ). Necessary to prevent any arcing on low beam relay :shrug:.
Reactions: Capt. Bob
I won product from Gordons Heated Gear
The Gerbing family back in the business.
http://gordonsheated.com/
I like mine and I think they are having a special right now...?
1 - 14 of 14 Posts
