1 - 18 of 18 Posts
2018 Goldwing Tour DCT
Has anyone tried mounting driving lights in the cowl with this type of bracket? Really like these lights and it would be awesome if I could get them mounted up. Thanks!
Automotive lighting Automotive tire Headlamp Camera accessory Rim
Camera lens Digital camera Automotive tire Point-and-shoot camera Reflex camera
2020 DCT Tour, Red/Black
These should work for you. its the same design. However, you might need to modify a bit and shim it. Also, you can find stock Aluminum at Home Depot/Lowes to make your own. I would add a star lock washers to keep all hardware in place. Nice project to do. The Rivco bracket provided makes installing the kit quickly. All OEM mountings come out. A guy in my group had installed them.
I mounted some that were similar. It took a while to design and make the $2 bracket to mount the $29/pair lights.
Nice !!! I saw these lights on SUPERBRIGHTLED.COM. What's the brightness/lumens on these? Its hard to see the rim around, put some foam in the cavity, if haven't done so.
I had to look them up, but they’re advertised as 12w and 1200 lumens. I’ve put them on 3 of my bikes for visibility mostly. I had under mirror lights to do the heavy lifting.
Vehicle Automotive tail & brake light Automotive lighting Hood Automotive tire
Discussion Starter · #12 ·
What brackets are you using for those lights? I’ve looked at the Denali bracket and the bracket on wingstuff. Haven’t decided on one though. I like the simplicity of the Denali bracket. But that doesn’t always make it the best choice. 🤷🏻
I think the OP is looking at these lights. Long Range Optimus LED Auxiliary light Round-CIL-OPR110 (cyclopsadventuresports.com)
Price has gone up since I bought them for my GS. I did line up next to a buddy with clearview lights. Very close in performance for 1/3 the price at the time. I liked the 10/20 degree combo.
I have the Honda OEM foglights on my wing and IMO they are pretty much a decoration and useless.
Reactions: Al P.
1 - 18 of 18 Posts
