So yesterday after a three hour tour at Disneyland, we returned to the DCT to find a completely dead battery.
I don't think it's the battery. I think the bike didn't turn completely off. This happened once before, but I caught it after 15 minutes--the headlight was still on. This time I didn't look back, just walked away, and when I got back....nothing.
Luckily, I got a battery jumper for Xmas, which I had put in the left saddle bag. Unluckily, I didn't have anything thin enough to use to pry off the panel that exposes the key slot that opens the left saddle bag. I finally managed to pry it off with my fingers, then used the key to open the saddle bag, then used the battery jumper to start the bike.
The first time the bike started, everything on the screen was flashing. and it wouldn't go into gear. I turned off the ignition and tried to restart, but it hadn't been idling long enough. I reconnected the battery jumper, and restarted it, and then it would go into gear, but the check-engine light stayed on the whole 45-minute ride home, and it was idling too fast. After sitting overnight and charging the battery, the check-engine light was still on. I disconnected the negative cable let the bike sit for half-an-hour, reconnected the battery, restarted the bike (without touching the throttle), and let it warm up until the fan kicked in. After turning the bike off and back on, the check-engine light is off, and the idle is normal.
The main take-away is that carrying a battery jumper is a good idea.
I'm wondering if at least some of the reports of dead batteries aren't because of a batch of bad batteries but are instead the results of a bug in the software that occasionally fails to turn the system off.
