Legend in His Own Mind
If I plug the 3.5mm auxilary plug in the left pocket into my radar detectors audio output jack shouldn't the detectors audible alarm cut in over a headset or the external speakers??? It doesn't.
The wing has a stereo female plug
The detector has mono output. They do make a mono to stereo adaptor (Radio Shack). I tried the above set up and it did work but had some buzz feedback though.
I'm probably not quite understanding ...
The aux plug in the left pocket is connected the AUX button on the panel.
So what I don't understand is what do you mean by "cut in"
... so if you're listening to something like the radio then no, it won't cut in over that.
This is probably obvious but sometimes it's the little things
.... it will come over the intercom but it won't come in over the FM or AM radio since by selecting them you no longer have the AUX selected.
If you have AUX button selected you should hear whatever is connected to the AUX plug ...
is there a "test" button on the radar detector you can push while connected to the plug and the AUX is selected on the panel?
Have you tried plugging anything else in your your aux plug?
... can you hear it?
Dennis
Give Kennedy Technologies a call and check if one of their wiring harnesses works on your radar detector. I have a Valentine One and my Kennedy harness blends my Garmin GPS and my radar audio all into with my XM and CB and works like a charm.
http://www.cellset.com/Motorcycleitems.html
DaleC
Txs Dale,
Thats what I needed to know. That should do what I want to do.
