I am going darkside soon and wanted to know if I can completely disable the OEM TPMS and the blinking lights from both dummy warnings?
That's because you only disabled 1 of the 2 indicators (if the diagram you posted is how you partially disabled your TPMS). If you ground out the other indicator (Bl/W), then you would not have to remove the wheel sensors.On previous thread I showed the way to disable,it is located under the right fairing pocket....The wheel sensors MUST be removed to make the light stop blinking after doing this..At least in my case thats what I had to do.
