Was giving my girl some love today and investigating a sticking intercom button when things went bad! After removing all necessary items to service the air filter i removed the audio unit to clean and inspect it for my button issue. After disassembling and cleaning all dust and debris in the button side of the unit I found that the rubber detent for my intercom button is loosing its spring. I fashioned a little support shim from plastic to see if this would help short term and reassembled the unit. So i then proceeded to install my new air filter and reinstall all components and reconnected all plugs and this brings us to 6 hrs ago... Bike starts and runs fine, audio turns on, volume works, station changes, all sounds good. But I have nothing on the LCD display, no clock, and the spring adjuster is inop. So using the factory manual and any remotely related topic from here I have come to my brothers for different views and help with my issue. I was unable to find any diag for the display unit in the service manual except for a reference in the stereo section from "test D" that said I should "Refer to the service manual for the gauge panel diagnostics" a section I was frustratingly unable to find! I have power from all the right places from the schematic on page 2-4 of the ETM section of the manual, Checked some grounds and then did it 7 more times to finally need to walk away for now and seek a fresh view another day.
Question and food for thought besides the obvious, 1. Is there a supplement manual just for the gauge panel? 2. Is there any testers for the LCD/gauge cluster or Audio unit at the dealer? When I was cleaning the button control side of the audio unit during reassembly I discovered that the bit I had been using to remove the screws from the the cover and the housing was a magnetized one, To my best recollection it never touched the circuit board, but its just been eating at me that it could have caused a problem, especially since I have yet to find any way of testing either unit independently. Thanks in advance for any and all help with this one, now its time for half a bottle of Advil and some sleep.
RR
RR
