I was installing the EC panel and fuse block today on my '06. I stripped the head of the screw on the accessory terminal where the trigger wire should go.
I'll try my Dremmel to cut a slot tomorrow. Any other ideas should that fail? Also, what is the screw directly under the accessory terminal for? The recommended alternate connection is to a relay wire. I dont see that relay on the cover, and I don't know where to find the correct wire for the power tap. Are the '06 relays different from previous years?
