1 - 3 of 3 Posts
I bought a Auxiliary light kit for my 2010 1800 GoldWing. Part # 01294-9,04/17/07. I did not like the switch provided, and bought one from Honda.
I see that the instructions say to: attach the bullet connector from the switch to the white wire from the wiring harness. Do you modify the factory switch with a bullet connector? If so, which wire is used in the connector from the factory switch? The OEM switch that I have has 3 wires going into the connector. The switch that came with the kit also has 3 wires in the connector, but does not have a bullet connector on it, either.
Thank for you help
Dennis
Thank for you help
Dennis
I am not familure with the EC kit but can tell you there are no bullet connectors near the LF pocket. Hope that helps.
Call Lewis. He will help you. Great company. Great guy!
tech help: 865.219.9192
order line: 800.215.6168
facsimile: 865.219.9292
1 - 3 of 3 Posts
