1 - 4 of 4 Posts
I am getting power for my accessories (led lights etc) from the ACC TERMINAL on fuse block. I am using both the positive and negative terminals at the fuse block then running through a terminal strip for +12vdc and a separate one for ground, is this ok or is it best to pick ground somewhere else?
Also what is fuse #11 RVS.A and #12 RVS.A used for? When do they have power on them. I checked them with the key on and off and there never seems to be power applied to these 2 fuses. (Maybe they are reverse fuses?)
Thanks in advance.
I'm not sure about the power location but I think the fuses are for your reverse, Try turning on you reverse switch and it should pwr the up. :idea:
Bill,
I just came in from installing some accessories on my 04. I purchased the Electrical Connection accessory fuse block and ground block. Nice fit and finish, easy install and enough space to add lots of accessories. Most of my stuff was LED's and such, but still was nicer than loading up the terminals on the battery. JMO :sw1:
1 - 4 of 4 Posts
