I got an 05 so your saying its just ground that goes bad n bypass it ?
Yes, a better fix is to run a ground wire to the G2 ground for it, but this takes alot more time and effort than just bypassing the connector. This is a disease started by GM years ago. Poorly fitting pins in the connectors and too much load on a single wire.:roll:
One major factor in this issue is how often or how long you sit with your brakes on. The brake lights, tail lights, and turn signals all use this same ground wire. When you put on your brakes waiting to turn with a signal on, there's a bunch of lights on behind you all grounding through that one wire... now add a trailer controller/convertor, saddlebag trim lights, and any extra brake lights that don't use the ground in C14.
On the 01-05 bikes, there's 6 21W brake lights, 6 5W tail lights, 2 21W turn signal lights, plus the 5W license plate bulb, as well as the trunk lock assembly and all the bag's latching switches using that one ground wire. That's at least 161 watts back there while you're applying your brakes. That's almost 12 amps with the alternator at 13.5 volts all running through that one wire. This isn't even counting the flashing turn signal surging an extra 1.5 amps everytime it flashes.
