1 - 3 of 3 Posts
I hooked up my trailer to test the lights today, had no brake lights. When I used my test light on the trike plug it must have blown a fuse or a relay. I now have no tail lights on the trunk, but they all work when brakes are applied. also none of the gages work & the reverse light is out. I tested all the fuses in the fuse box & under the seat. all tested good.
Does any one now where there might be another fuse or what relay to check? I have an 04 Motor Trike 2+2
check fuse # 20 I believe, don't have the fuse cover in fromt of me. Should be 3rd down on right side of bank - labeled rear running or something like that. I blew that fuse srewing wiht my trailer on Sunday. Did what you're talking about. 20 amp replacement.
It turned out to be fuse #5 look good but was't. Thanks for your help.
1 - 3 of 3 Posts
