1 - 17 of 17 Posts
On the fuse panel - ther are 2 screws (contacts) for auxiliary power.
Are they both '+' ? meaning that you can add 2 items and ground somewhere (battery?)
or
are they '+' and '-' ???
Thanks!
On my 06 one of the screws is " + " & the other is " - ".
I just checked my 2002 owners manual and it did not specify. It did say 5 amp max load. Also, sticking with convention, if one terminal is labeled with + then that means +12 Volts and the one lebeled with - implies a ground point.
The top one is positive and the lower one is negative. There is power at this connection with the key in the on or acc. position. Be sure to fuse any connections made to these terminals.
Thanks, guys!
I actually thought that it is fused already. As MotorcycleBoy also mentioned.
Just don't exceed 5 amps on these terminals. Honda has put out a tech bulletin on this, so I have to believe there have been some associated problems with overloading these accessory terminals.
I use the switched accessory terminal to turn on a relay to control higher amp accessories. Doesn't burn up bike wiring that way.
icing777 said:
Is 5 amp. enough for an Autocom?
Yes with plenty spare headroom.
Nigel Fenton
Yes, Nigel is right, the Autocom probably pulls less than an amp, even at full volume.
The positive accessory terminal is fused, but the negative terminal is not, and several folks have burned up part of the wiring harness by attaching a ground block to the negative accessory terminal lead and then hanging all kinds of grounds on it. They use a light gage wire for the leads to/from the accessory terminals, and they won't handle a lot of current.
Good Point! I never even thought, until now. That someone might run the hot wire for thier new driving lights direct to the battery then connect the ground for these same lights to the negative side of the accessory terminal in the fuse block. That would cause a melt down of some sort.
Discussion Starter · #14 ·
Now you are talking above my head, Fred and Motorcycleboy :roll:
Why would there be a problem?
Where would I wire the driving lights then (cause they are on order)
Thanks!
Get an aux fuse panel from EC. http://www.electricalconnection.com/pow ... pplate.htm
It really cleans up all the extra wires from add ons and they are switched with the key. You can get their ground plate or go to Radio shack and get one for $5 that fits perfectly above the battery. Just run a heavy jumper to the negative.
Thanks!
The driving lights should come with good instructions on wiring. I have used Electrical Connection and Tulsa; both had good instructions.
If you follow the instructions, the hi-amp wires go direct to the battery (fused). The lights are controlled by lo-amp wiring and a relay. Should not be a problem for you. :wink:
1 - 17 of 17 Posts
