I have never had the bike die after coming to a stop.Does anyone have this issue? Has happened twice to me. This happens when the engine is at normal temp.
The DCT clutch initialize learn procedure is done at the factory. It is not done as part of the delivery/setup process unless problems were discovered during the setup/test ride that required the procedure to be performed.It has happened to several people including me. It seemed to be a problem with low mileage that goes away. Try doing the initialization for the DCT Fred has posted at the top of this board. I think it happened to me last time when I had under 1500 miles. I can't say for sure but I believe that many bikes leave the dealership without being done. End result of initialization is quieter and smoother shifting and I believe the stalling hasn't happened to me since.
Which transmission?Does anyone have this issue? Has happened twice to me. This happens when the engine is at normal temp.
I had a dealer keep my new at the time 2014 BMW K1600GTL Exclusive for 3 months during riding season. They then screwed me big time the next time I took it in for service. I have never been back to that dealer since. I is NOCO Motorsports in Fort Collins, Colorado.Thanks I will do this when I get the bike back, Dealer has had it for 2 + months now.
Agree.... if your from Canada it’s a feature built in. It can be turned on or off at you discretion.almost sounds like you got a Canadian bike, they do that as a feature
The OP (Machgun) said: "Thanks I will do this when I get the bike back, Dealer has had it for 2 + months now".I f your engine dies when you stop something is wrong. Your bike is under warranty---use it
You let them keep the bike for 2 plus months.Thanks I will do this when I get the bike back, Dealer has had it for 2 + months now.
MuffThe DCT clutch initialize learn procedure is done at the factory. It is not done as part of the delivery/setup process unless problems were discovered during the setup/test ride that required the procedure to be performed.
:doorag:
That is what I was thinking as well. However this "feature" can be turned off thank god....almost sounds like you got a Canadian bike, they do that as a feature
I agree!! It’s probably outside in the back collecting dust ‘till they figure something out! >You let them keep the bike for 2 plus months.
What's up with that? I would never let that happen to my bike for whatever reason.:smile2:
OP need encouragement not discouraging comments. Help not harm.:wink2:I agree!! It’s probably outside in the back collecting dust ‘till they figure something out! >. Go there & get your bike back . . . NOW!!
