Hi Guys.
As a new Wing owner I haven't had the opportunity to strip my Wing down to its underwear like some of you have, so I am hoping you can give me some advice.
I have an 05 wing that has started leaking oil from the top of the case, on the right side, right at the back of the engine. I have attached a picture here so you can see where it looks like its coming from.
As you can tell, this is behind the right side cover and deep behind the rear brake fluid reservoir. Of course I can't see in there very well, and was surprised I got the picture I did. Anyways, my first question is, what's up in there that could be leaking? If it seems like there are a few things that might be causing the problem, I will try to tackle this myself. If no one has any idea, then I guess its off to the dealer. I'm not a big fan of most dealers.......
The left side is totally dry.
Loose case bolts is the obvious I guess, but I don't know if there are any sensors or fittings up there that could be leaking. Any ideas?
Thanks,
Thanks,
