It seems like there used to be lots of discussions on this board regarding riding how-tos, but that traffic seems to have diminished with the passage of time. However, I was riding around last night and a question came to me. My question is, how close can you evaluate how much clearance you have remaining in a turn? Do you know pretty close to when your pegs will drag? Do you frequently misjudge and drag your pegs when you expect to have plenty of turn clearance? Do you know when you need to slide off off the seat or do you sometimes find yourself scraping pretty firmly while your rear end is firmly planted in the middle of your saddle? The reason I ask is I frequently find my judgement off some amount. I also find that the more I practice tight corners, even at < 30 mph in a parking lot, the better I can predict how close I am to dragging the pegs. I am absolutely not skilled enough to drag hard parts in a corner. The only time I've done that was when my front tire went out from under me and I slid off the outside of the corner on the engine and saddle bag protectors. That was definitely not my desired outcome. :surprise:
When I ride I try to take a few minutes to practice tight turns. I'm trying to get to the point that I can drag both pegs all the way around a circle while idling in third gear, but I'm not there yet. Once I can do it in 3rd gear then I'll start using the clutch friction zone and the brakes.
I also find my comfort level to be different when I'm pushing corners going right and left. Especially if I can see all the way around the curve, it is much easier for me to push harder into a right turn than a left turn. If I overrun a right turn and I can see there is no one coming the other way going a bit beyond the center line does not give me much of the pucker factor. OTOH misjudging a left turn and running off the outside of the road certainly has a high degree of fear going along with it.
I also feel like I have a lot more lane to work with when turning right. If my head ends up hanging off the inside of the turn when I'm leaning into a right turn, that is no big deal. OTOH, if my head hangs over the middle line when I'm turning left, I think that is a big deal as that is certainly a good way to get my head whacked by a vehicle in the other lane. This difference makes me feel like I have a lot more road to work with on a right turn than I do on a left one.
Any thoughts on my ramblings?
