Perhaps, but the system itself seems to be problematic IMO due to all the very minute orifices and passages, as well as being somewhat of a "Rube Goldberg" design...That seems to have lacked the proper maintenance when it was mounted...?
How do you come to that conclusion?That seems to have lacked the proper maintenance when it was mounted...?
Lol so we see why proper maintenance is important. Not all Recommendations by Honda warrant the the hurry up must do attitude IMO but brake, coolant I follow closelyPerhaps, but the system itself seems to be problematic IMO due to all the very minute orifices and passages, as well as being somewhat of a "Rube Goldberg" design...
Fair hypothesis, but this is a part from a twelve-plus year old motorcycle. dadztoy might have mileage that was on the motorcycle it was removed from, but we have zero information on service history from this specific find.seems like parts and fluid are dirty.... as seen on picture 4
What are those ??? Also, how do the bores look ???BTW - I was up on the Cherohala this afternoon checking Fall colors... I usually ride the downhill part (heading toward Tellico) fairly aggressively using liberal amounts of rear brake searching for judder... Today, at 70 degrees, none was present... kwthom and myself have been working this problem for a while so the disassembly of the PCV was the "next step" in our/my research...
Now I know how it comes apart so I'll probably pull mine during the down winter months here as I'm doing routine maintenance on the bike... I built a pressure bleeder earlier in the month and ran several liters of fluid thru the system... That seemed to help, but the judder was not entirely eliminated and both kwthom and I have come to the conclusion it is a heat related problem along with possibly air in the lines and dirty, goopy. fluid...
The PCV lives behind the left radiator and that gets me to thinking about the heat related issues - that's one of the reasons I want to see it's location on the bike... Perhaps some heat shielding might help - just another thought...
WATCH THIS SPACE!!
Les
Thanks for clarifying this, for us non-mechanical types.View attachment 338217
The proportioning control valve, not a positive crankcase ventilation valve, isn’t cheap either.
I think he is looking for the hot-bike-shudder under braking.
Yeah, I know, I’m so old school.
Heat and location, interesting thesis, but I would interject that the heat would be affecting the springs and seals inside. I’ll keep watching. :nerd::nerd:BTW - I was up on the Cherohala this afternoon checking Fall colors... I usually ride the downhill part (heading toward Tellico) fairly aggressively using liberal amounts of rear brake searching for judder... Today, at 70 degrees, none was present... kwthom and myself have been working this problem for a while so the disassembly of the PCV was the "next step" in our/my research...
WATCH THIS SPACE!!
Les
Yeah, lots of ideas and thesis' - maybe one day we'll find the actual cause...Heat and location, interesting thesis, but I would interject that the heat would be affecting the springs and seals inside. I’ll keep watching. :nerd::nerd:
Sounds good to me - I don't have a clue as to how it works and at least that makes sense...Looking at that video and applying it to our bikes, here is a theory.
When you apply just the rear brake, you have a higher pressure on the input side of the delay valve, than the output side.
Once you have reached enough pressure to open the delay valve, the input pressure is reduced because it is now feeding the output side(s) of the delay valve.
I'm sure there is some built in hysteresis, but if there is enough air in the output side, the pressure will drop more than planned. If it is hot, that air is now expanded (taking up more volume) and would cause an even larger drop of pressure causing the delay valve to get into a chatter mode.
I'm not an engineer, but I play one at home.
