1 - 9 of 9 Posts
OK, I bit and mounted a Falken before embarking on our west coast tour last couple of weeks. The wear was great, hardly noticable in 5300 miles of very hot running pulling an Aspen Classic camper. Now before you start, I have pulled the Aspen many, many miles using Bridgstones, so I know how to load it and pull it correctly. The trailer pulls very well.
I noticed two thing about the CT that was a little concerning for me.
First, in higher speed curves (60-75 MPH) I felt a little too much of what I suspect is side wall flex, causing a slight tail wiggle.
Second, the square profile tends to "climb" truck tire grooves or "overlaps" in pavement worse than the BS.
Am I alone in noticing these or do others find similar issues?
No that sounds about right. The Falken was my first C/T. I have never pulled a trailer so I don't know how that effects things. Did you try playing with the tire pressure any?
What Murgie said.
MM
What psi ?? 44 works great for me !!
It's all about the PSIs!:thumbup:
Based on some posts here, I have the tire at 37-39 PSI. It rides great but may need more air for 2 up and trailer?
I run 44 in mine and pull a trailer. I played with the air pressure and found that at lower pressures.. below 42 the tire responded like yours. i would up the pressure at least to 42 or 44.:doorag:
:agree:
1 - 9 of 9 Posts
