1 - 15 of 15 Posts
I have recently purchased an 03 goldwing with 15k miles on it and recent new Metzler tires, put on before I bought the bike. I have a roar in the rear of the bike when I turn left or lean the bike to the left at about 40 mph up. It's also there on a right turn or lean but only slightly. It is still there when I pull the clutch in and coast at these speeds. Please chime in if you've had or heard of this problem and know of a cure? I'm in the process of draining the final drive, it did have the correct amount of gear oil in it, about 4 ounces and I plan to put Amsoil oil back in it tomorrow. Everything seems tight and it has no wobble in it. Any help appreciated.
Thank You
Danny
You said new metz installed , lots of guys says these tires are very noisy, high whine to them, just check or change the rear hub it's easy I use nothing but mobil 1 rear end lube synthetic, probably just fine your looking for a weird noise it's new to you and there are many, just look around on the rear swing for cracks while your changing the hub oil...snow...
Legend in His Own Mind
It's not a final drive problem per your description. Sounds like a tire issue for sure.
Same with my 02 :roll: I have always run on Bridgestones except when recently forced to buy the only rear tire on the shelf which was a Metzler.
Oh boy does it howl when leaned into a corner. It is positively the rear tire in my case.
Discussion Starter · #9 ·
Thanks for all the input, I feel alot better........
Thanks everyone, I feel alot better........
Danny
Rear tire most likely. In many cases it sounds like teh front tire because teh sound is reflecting back at you from wind screen.
It could very well be tire noise, however considering the rear of the bike is designed around a single arm it is also possible there is more flex and with that flex there might be a little noise associated with it. I have noticed a small amount of roughness and increased rumbling from mine under similar circumstance. I am of the opinion it is normal but being older and used to traditional design I can't shake this nagging feeling that the arm isn't as strong and subject to failure. No issues of this nature have surfaced yet thank goodness!
LAW
Noise
It has been my expeience that what you are hearing is just the noise the tire tread pattern makes when we lean the bike in a turn. Relax and enjoy the ride, I certainly do these waining days of our riding season.
Discussion Starter · #13 ·
I really didn't expect to get such great response to this guestion from so many intelligent people and I want to say Thanks to all who responded, I don't have the knowledge to compare the stock tire to the Metzler so this is great information, once again THANKS.................
Danny
TIRES! Are they just a little bit Cupped? Then again, TIRES!
I had an identical noise when my Metzlers had about 10K, continued riding them until 16K. Replaced the rear only with a Bridgestone and noise went away. I still have mileage left on the front Metzler, so I am not going to change it yet. I do have some decel wobble, but a Bridgestone will be going on when I replace.
1 - 15 of 15 Posts
