Honda Brand from my local dealer every 10,000 milesWhat brand of SAE 80 hypoid gear oil do most of ya"ll use for your 1800
thanks
thomas
Honda Brand from my local dealer.
I use the amsoil severe gear syn and every 16k.I just did it it was so clear clean the new oil looked the same.What brand of SAE 80 hypoid gear oil do most of ya"ll use for your 1800 and how often do you change it.
thanks
thomas
I use Amsoil 75W-90 synthetic & change every year. This is one area I believe synthetic makes sense for even the frugal minded people. Because it only takes a few oz's, buying the 'cheap' stuff will save less than a dollar per change so less than a tank of gas over the life of the bike & since you can safely go longer each change it would be a wash.What brand of SAE 80 hypoid gear oil do most of ya"ll use for your 1800 and how often do you change it.
thanks
thomas
When was you all's first change? I read on here that some suspect that Honda puts some sort of additive in and you should wait on your first change. Not sure if there's any proof of that or a rumor.
+1I change rear drive oil with amsoil severe gear syn every time I change engine oil although the drive oil never looks dirty the magnetic plug is usually full of crud
The brand is incidental as long as it meets the API spec that Honda recommends. Check level quarterly and change per the owners' manual.What brand of SAE 80 hypoid gear oil do most of ya"ll use for your 1800 and how often do you change it.
thanks
thomas
