I took the G-Max out on it's maiden voyage today after taking all those pictures which will come later! I run up into Tenn. on a 115 mile run with 44psi in the tire.(remember I only go 35mph)
Where do I want to start? Well first it is taller and put my speedo of only 3mph instead of 5, that's a plus. Running 100 miles on the GPS, wing showed 103.1.
The tire rode pretty nice although I don't think 44psi is enough air for the twisties. The rear end felt real squirrely on the curves, I will try it again at 46psi. It could be harder rubber than I am use to, but it felt like sidewall flex to me. Could be this tire has to be scuffed in more! The bike transitions left to right pretty easy, but not quite as easy as my Sunny, although it isn't far off. I did get a chance to run it some on wet roads also and it seemed just fine to me.
As of right now it is the least favorite of the four C/Ts I have run, but that could change with a couple of minor adjustments! Time and miles will tell!
