1 - 9 of 9 Posts
I have an '04 wing and installed multiple LED lights, to include turn signals. I have the new three prong flasher control unit to bring the timing back to something normal, but can't locate the old one. I hear the noise from up under the instrument panel, but can't spot the unit itself... Anyone know where it's located? thanks!!!
It's under the windshield pan You'll have to pull it...
thanks, Larry.. I've got it all off, exposing the back of the instrument panel... but what does it look like? I don't see anything that looks like the replacement,,,
From Techdude2000
Larry, thanks for the effort... I took that module out and disconnected it... its a five-pin connector, and with it disconnected, I still have flashing turn signals and four-way flashers.... don't know what it is, but its not the flasher relay.. any other ideas? I'm pretty discouraged and about resigned to just live with my "fast" flashers....
Larry, can't thank you enough... I found that 3-wire connector under the windshield bracket, and will try to hook the new flasher relay up to it tomorrow.
george
I know you did this already but there is an easy/quicker way just remove the speedo rather than the windshield this video is for a later bike but the only difference is you remove the speaker grills and there are screws and clips behind them.
1 - 9 of 9 Posts
