Going from Atlanta to Birmingham on I-20 for MotoAmerica last weekend. Had the wife on the back with as much luggage as a Wing can hold. Speed limit is 70, traffic is running 80, and I like to run a bit above traffic.
When I pull off the exit for Barber, I feel that horrible wiggle that says "you have a flat". There was absolutely no indication that there was a problem until I got down under 10mph. The tire was so hot it was about to melt.
I pulled into the gas station across the street only to discover my valve stem was broke off. How did this happen just going down the road? So now I am in a pickle.
We hop back on the bike and make the super slow 2 mile trip to the track, where I explain to the lady at the gate that I need to get to the pits where I can get some buddies to help. She says I can go in, but not the bike. Huh? Do you understand I have a flat tire and need to go in get it fixed? Yes sir, you can go in, but not the bike.
I did not have the wrench for the axle, so I go in, take the tram to the pit, borrow a wrench, take the tram back to the bike, pull the wheel off, tram back to the pit. Dunlop race services was incredible. Popped the tire off and installed a super high-zoot chrome racing valve stem, put the tire back on, and balanced it to a gnats-arse. It was a bit of a pain for them, as they are set up for 17" wheels, but they made it work. Good thing the tire was "good enough" to get me home, as there was not an 18" tire within miles. So now I tram back to the bike, put the wheel back on, tram back to the pit to return tools, and tram back to the bike.
What did I learn? I'm not sure. I will carry a wrench for the axle from now on, but that wouldn't help in most situations, although it would have in this one. I suppose I learned that I will not use rubber valve stems again.
I also learned that a flat front, as was the flat rear I had years ago, is not noticeable in a straight line at speed.
If my exit had been a turn, things may have been a lot worse.
