I have the EC lights on mine and they still work with high beam onI tought EC was using the OEM wiring, witch switches the foglights off when put headlights on.
Unfortunately that wont work for the OP. He has a 2018. That harness is for the 2001-2017s.You can also get this: http://wingstuff.com/products/30650-fog-light-reconfiguration-harness
I live in Colorado and have never been bothered with my other bikes having both the high beams and fog lights on at the same time. When I had my K1600GTL I had not only a set of Clearwater Ericas and Darlas but they worked with both low and high beams. I will keep looking for a solution as this is a safety problem. Once again big brother knows better then us what they think we need.
On my work bike I do not have this problem, We can and do run fog LEDs high and low beams plus our take down lights. On the other side of the equation we can no longer run stealth mode with all our lights turned off. We had to get all our bikes modified to run the brake light.
I will find a solution to the fog light problem.
