I've got a stuck ADV and will rebuild the entire front end, installing Progressive springs and All Balls bearings. Questions:
1. Where can I get the O-rings for the ADV unit?
2. Should I replace the fork seals? Mine seem fine, have 25k on them.
3. If I should replace the fork seals, what is the part#'s that I need? I understand that there is a special "seal grease" required. Does Hal sell that?
4. Should the fork seal dust caps be replaced?
I've been reading all the posts and studying Freds DVD's. Any other advice/tips/tricks/needed hardware/etc. in this area is greatly appreciated.
Thanks!
Thanks!
