Thought I would change the fork oil. The crush washer on the drain bolt didn't come out with the bolt. I have tried hooking it with the bolt and shaped a small screw driver to have a hook. It is in the same position as when its seated. I can't get it budge. Anyone else ever have this issue, and how did you get it out. I finally got frustrated with it, and had to walk away for a few minutes.
