1 - 4 of 4 Posts
What weight of fork oil should be used? I can't remember exactly where I seen it, but I think Honda calls for 5wt fork oil. Anyone I talk to says that it should be at least 10wt. Just looking for some input from the board on this.
I think the actual weight of fork oils may be a bit arbitrary. The Honda 10W may be closer to a Belray 5W. Use the OE oil for that cushy lousy OE feel...... :lol:
I always use 15 weight belray the front ends on wings are already iffy, so the little heavier weight helps, even when I install progressive I put in 15, if You can't find 15 weight Harley type F is 15 weight
1 - 4 of 4 Posts
