Found corroded ground wire while installing fuse box.
I found the engine ground wire on the left cylinder head corroded. The right side was not as bad. I just had the gas tank out doing an ABS repair, I believe I could have replaced the wire while the tank was out.
But now the tank is back in I did the next best thing, added a 8-gauge wire from the head to the battery. The bolts had corrosion also, cleaned threads and replaced bolts, dielectric grease.
Here is photo of the fuse box and the ground wire.
