Okay, I've decided to try and learn a little more about my bike and try to save a little money in the meantime. I needed a new rear tire and brakes to pass inspection here in PA. I pulled my front and rear tire to give them a good cleaning and polishing and check both sets of brakes. Took the fronts off and cleaned pistons as per Fred's videos. Pads still looked pretty good. Just switched the lefts and rights as a few of you have mentioned. I'm slow but got them done.
Here's the problem. The rear brakes came out easy. However, when I cleaned the pistons and tried to push them back in I could get the bottom two in till there was about a 1/4 inch left but the top piston is out to the caliper. When I get that pushed in the bottom two come back out. When I try to push them all in at the same time, I can't get them to move.
I have tried everything I can think of. I searched this site for suggestions. I have tried c-clamps, a long screwdriver, a piece of wood, opened up both brake cylinders. I'd like to try pulling the caliper but not sure how.
Any other suggestions?
