Can anyone please explain this to me?
I just replaced my front brake pads on a 2008 GL1800 I purchased used 3-4 years ago.
The brake pads came in a set of 2, and all pads looked like the same thickness, although I did not inspect them real closely.
After installing the pads, and a couple weeks later, I took the 2008 GL1800 for a ride and noticed a dragging noise coming from the front wheel area. Upon further inspection I found that the left brake disk, but not the right disk, was dragging on the rotor. It appears that this has been happening for a long time (or someone filed out a piece of the rotor) because the rotor had a grove in it where the rotor was dragging in.
As I closely inspected the right brake pad (the one that does not move) it seems as if it is all the way up against the caliper. Since it is all the way against the caliper, the disk has to rotate against the left side of the caliper, as opposed to the normal rotating between the disk pads and not touching anything. The pads I purchased were for a 2008 GL1800 and the right front brake caliper and pad fit properly, with nothing rubbing. But, the left caliper brake pads do not fit properly. I have seen enough GL1800 calipers over the years that I am pretty sure that both calipers are the ones designed for this bike.
Attached is a pic of the caliper. As you can see, the brake pad on the left in the pic (non moveable one) is all the way against the caliper and cannot move any farther left to accommodate the brake disk so that is would not rub the caliper. You can also see on the right side of the caliper (right in the pic) that the disk is rubbing the caliper.
What I am missing?
Unfortunately I already threw away the old pads, or I would try and install the thinnest one against the caliper in hopes to move the disk left and away from rubbing the caliper.
What I am missing?
