1 - 8 of 8 Posts
For a front brake pad replacement, does the pin in bottom of the caliper drive out. If so, does it take a lot of force?
Thanks,
Dale
Red,
It's not a bolt. Do the three bolts on the side of caliper, "not the 2 holding the caliper to the fork" come loose to expose the pads?
Chard Member
dnifong said:
Red,
I don't know what you're doing and you don't either! :oops: LOL...
Remove the little rubber plug at the bottom of the caliper. Behind it is a 5mm hex head. Remove that and the pads will fall out......
Thanks Red,
I need better light in the shop. I could not see the plug until you pointed it out.
Thanks again
Buy Freds CD's........takes the guess work out.
Thanks again Red,
I was trying to drive that pin out of the other side. I did not hurt anything. It only takes a minute when you know how it works.
Dale
I had this view in my head of the calipers hanging there by the hoses.
:arrow: :lol: :lol:
1 - 8 of 8 Posts
