to do a brake job on a gl1800 all you need to do is remove the 3 bolts on the back of the wheel cylinder. separate the front have with the back half and change the pads. i was looing for this before i took it all apart. good luck, its easy.... you will need to push the pistons in to put the new pads on....:thumbup:
