I've searched through everything here and cant find anything about how to remove the rear section of the front fender. I have removed the two front bolts (obvious) and found the rear bolt on the left side (a little less obvious), but I can locate a bolt head for whatever is holding it on the right side. All the bolts have 8mm heads, and on the right side, there is an 8mm bolt head going through some sort of brake line bracket, but when I losened it off, it didn't same to be the right one. Even the shop manual doesn't shed much light, as it doesn't show the location of the right-side bolt(s).
Any suggestions and/or pictures would be helpful. Even Fred's DVD didn't help..., they only show removing the front section and caliper covers.
Thanx...
Thanx...
